10-10-2017 09:26
10-10-2017 09:26
I downloaded the update and have signed in on fitbit studio as well as turned on developers bridge. However when i go to connect my fitbit it doesnt show it instead finds and connects my phone. How can i fix this?
Best Answer10-10-2017 21:34
10-10-2017 21:34
There are 2 clients of the developer bridge. One is the phone and the other is your Ionic.
Normally you only need to initiate the developer bridge from your Ionic (Settings > Developer Bridge), unless your application has a companion, in which case you also need to start the developer bridge on your phone (Ionic > Developer Menu).
I hope that helps.
10-10-2017 21:34
I hope that helps.
