Hello all,
I have never had to work within memory constraints before developing my FitBit app. Before I published I decided to checkout how much memory this thing actually used.
I noticed that my memory is slowly ticking up and up by about 40 every second. Obviously this is not ideal because if the user leaves the app running for a while I don't want it to crash.
I have no idea what to look for when finding the memory issue... I made sure I have no variable declarations (let, const, var etc) in loops, but what else should i be looking for?
Could clock.ontick or setInterval have anything to do this? What else should I be looking for?
Thanks in advance!
Best AnswerThe memory will tick up but then get cleared by the built in garbage collector; at least that is what I observed working on my apps/faces.
Best AnswerIt looks to me like nothing is ever getting cleaned up and the memory usage just keeps growing indefinitely.
Best AnswerWell I feel silly now! I was watching my memory use tick up every second and I guess I didn't watch it long enough to see Garbage Collection actually happen!
Seems like everything is okay after all.
Thank you for the help!!
Best AnswerI was about to ask how you monitored the memory of your app because I recently hit the limit in mine, but then I found it, so I'm posting it here for anyone who has the same question: https://dev.fitbit.com/build/reference/device-api/system/#interface-memory
The emulator doesn't show your memory usage. I think it would be nice if it did. But a console log is almost just as good.
import { memory } from "system";
console.log("JS memory: " + memory.js.used + "/" + memory.js.total);
