08-23-2020 05:07
08-23-2020 05:07
Hi,
I need on Versa 2 in my app at least 5 min before screen turns off due to specifics of my app.
Screen wake using motion sometimes works sometimes not. This is not acceptable for my app.
How can I do this programmatically to prevent screen going off?
As you wrote you removed autoOff to protect Oled - but 60s is not enough in my case.
You just restricted it too much. How can you remove autoOff and not even allow to change it to 5 or 10 minutes.
On Samsung oled mobiles you can set it up to 10 minutes. And that would be enough for my apps needs.
Best Answer08-23-2020 05:50
08-23-2020 05:50
poke() helped me...
