10-25-2017 05:20
10-25-2017 05:20
Hi ppl,
I was trying to change the text color using an 'if statement' but I cannot get it to work.
I tried creating 2 ‘class’ styles in my CSS and then used this to change between the two...
if (blah blah) {
test.class= "test-white";
} Else {
test.class= "test-black";
}In the css I have the 'fill' property set to white for '.test-white' and black for '.test-black' but it does not do anything!?
I then tried using the classList.remove and classList.add methods but the debugging console reported the following: Cannot read property 'remove' of undefined.
Is there a way to change the text formatting based on events?
Thanks,
Steve
Best Answer10-25-2017 07:21
10-25-2017 07:21
You can't currently change the className attribute. You could set the individual styles though.
if (blah) {
// mything.style.fill = "green";
} else {
// mything.style.fill = "red";
10-25-2017 07:21
10-25-2017 07:21
if (blah) {
} else {
10-25-2017 07:26
10-25-2017 07:26
perfect, works great! Thanks for the support.
Best Answer01-16-2019 13:09 - edited 01-16-2019 13:21
As this thread is a little older now, I'd like to bring it up and ask the same question: With the new SDKs, is there a chance to change or add a class on an element?
That could be actually quite useful in my case, where I'd like to change the position on some elements depending on a user's input. The clockface I'm working on should be compatible with the Versa and Ionic. Working with alternating classes could help to keep the code a lot cleaner.
Thanks
Torsten
