Greetings brains trust,
I am trying to use the View thing with the header. I have the following code to create the header
<use href="#view-header" height="50" fill="fb-peach">
<set href="#text" attributeName="text-buffer" id="myTime" to="Annoying" />
<!--<text id="myTime">Something</text>-->
</use>
<use href="#scrollview-item" height="250">
<rect width="100%" height="100%" fill="fb-red"/>
</use>And trying to make a change to it using javascript with ....
const myTimer = document.getElementById("myTime");
myTimer.to = `${nowHours}:${nowMins}:${nowSecs}`;If I put the data to console, it displays, so I know that is working. but the following just gives me this error
Unhandled exception: TypeError: Cannot set property 'to' of nullI have tried with a text tag with the same result.
Any ideas?
