05-26-2019 06:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-26-2019 06:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
I have a panoramaview that contains two panoramaview-items. One of the items is a tile-list. Everything works until I add a checkbox-tile to the list. When the checkbox-tile is added to the list and I run the app I get the "Error 22 Critical glue error" message. The checkbox_tile_widget.gui has been added to the widgets.gui. If I replace the checkbox-tile with a <text> element, then the app works, so it must be something with the checkbox-tile. Also, I'm using checkbox-tiles in other parts of the app and their fine, only issue is inside the panoramaview. Any suggestions?
<svg id="main-screen-container"> <use id="main-screen-panoramaview" href="#panoramaview"> <use id="main-screen" href="#panoramaview-item"> <rect width="100%" height="100%" fill="red" /> </use> <use id="secondary-screen" href="#panoramaview-item"> <use id="wp-list" href="#tile-list"> <var id="reorder-enabled" value="0"/> <use href="#tile-list-item" class="tile-list-item"> <use id="wpItem1" href="#checkbox-tile" value="0"> <set href="header/text" attributeName="text-buffer" to="Invalid" /> </use> </use> </use> </use> <use id="pagination-dots" href="#pagination-widget" y="8"> <use href="#pagination-dot" /> <use href="#pagination-dot" /> <use href="#pagination-highlight-dot" /> </use> </use> </svg>
05-28-2019 11:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-28-2019 11:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
That error sometimes means an ID is missing where it's expected. Can you try putting one on the tile-list-item?
05-28-2019 11:35
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-28-2019 11:35
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I tried that and got the same error. I even commented out everything in my app except for one panarama view and one panoramaview-item and still got the same issue. My next step is to create a project from scratch, starting with the parnaoramview to see if that works. Do you know of any reason why a tile-list with checkbox-items can't be used within a panoramaview?
05-28-2019 12:47
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-28-2019 12:47
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I created a new app with just the panorama view. If I display a list of <text> then the panaorama view displays correctly. If I replace the list of <text> with a list of <checkbox-tile> then the panorama view does not show the first screen. All components have an id. Not sure where to go from here.
app/index.js
import document from "document"; let panorama = document.getElementById("panorama");
resources/index.gui
<svg id="parent"> <svg id="panorama"> <use id="container" href="#panoramaview"> <!-- screen 1 --> <use id="page1" href="#panoramaview-item"> <use id="tileList" href="#tile-list"> <use id="tlHeader" href="#tile-list-header" class="tile-list-item"> <text id="tlhText">Header</text> </use> <use id="tli0" href="#tile-list-item" class="tile-list-item"> <!--<text id="item0Text">Item 0</text>--> <use id="item0" href="#checkbox-tile"> <set href="header/text" attributeName="text-buffer" to="Checkbox Item" /> </use> </use> <use id="tli1" href="#tile-list-item" class="tile-list-item"> <!--<text id="item1Text">Item 1</text>--> <use id="item1" href="#checkbox-tile"> <set href="header/text" attributeName="text-buffer" to="Checkbox Item" /> </use> </use> <use id="tli2" href="#tile-list-item" class="tile-list-item"> <!--<text id="item2Text">Item 2</text>--> <use id="item2" href="#checkbox-tile"> <set href="header/text" attributeName="text-buffer" to="Checkbox Item" /> </use> </use> <use id="tlfooter"href="#tile-list-footer" class="tile-list-item"> <text id="tlfText">Footer</text> </use> </use> </use> <!-- screen 2 --> <use id="page2" href="#panoramaview-item"> <rect id="rec" width="100%" height="100%" fill="green" /> </use> <!-- Have enough pagination dots for your slides (extras are hidden) --> <use id="pagination-dots" href="#pagination-widget" y="8"> <use href="#pagination-dot" /> <use href="#pagination-dot" /> <use href="#pagination-dot" /> <use href="#pagination-dot" /> <use href="#pagination-dot" /> <use href="#pagination-highlight-dot" /> </use> </use> </svg> </svg>
resources/styles.css
.defaultText { font-size: 32; font-family: System-Regular; font-weight: regular; text-length: 32; } .tile-list-item { height: 80; } .tile-list-item text { height: 32; font-family: System-Regular; fill: "white"; }
resources/widgets.gui
<svg> <defs> <link rel="stylesheet" href="styles.css" /> <link rel="import" href="/mnt/sysassets/widgets_common.gui" /> <link rel="import" href="/mnt/sysassets/widgets/baseview_widget.gui" /> <link rel="import" href="/mnt/sysassets/widgets/panoramaview_widget.gui" /> <link rel="import" href="/mnt/sysassets/widgets/pagination_dots.gui" /> <link rel="import" href="/mnt/sysassets/widgets/tile_list_widget.gui" /> <link rel="import" href="/mnt/sysassets/widgets/checkbox_tile_widget.gui" /> </defs> </svg>
05-30-2019 07:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-30-2019 07:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Has anyone else seen this issue?
05-31-2019 11:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-31-2019 11:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I have also tried to add a checklist item to a panoramaview and receive the same error.
Seems to be a bug somewhere
01-10-2020 14:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-10-2020 14:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
i am also experiencing this, i have checked that everything has id's
07-10-2020 14:18
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
07-10-2020 14:18
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Yep, in my app, which uses a panoramaview with virtual-tile-list containing checkboxes, if I simply replace the:
<use id="item0" href="#checkbox-tile" pointer-events="all" >
</use>
with:
<text id="item0"/>
then everything works as expected.
Looks like a bug to me.
</code>
