11-18-2018 05:53 - edited 11-18-2018 05:54
Hello all,
i want to fetch a file from internet.
For testing I use the following code:
// Import Outbox from the file-transfer module
import { outbox } from "file-transfer"
// Source image on the internet
let srcImage = "https://placekitten.com/348/250";
// Destination filename
let destFilename = "kitten.jpg";
// Fetch the image from the internet
fetch(srcImage).then(function (response) {
// We need an arrayBuffer of the file contents
return response.arrayBuffer();
}).then(function (data) {
// Queue the file for transfer
outbox.enqueue(destFilename, data).then(function (ft) {
// Queued successfully
console.log("Transfer of '" + destFilename + "' successfully queued.");
}).catch(function (error) {
// Failed to queue
throw new Error("Failed to queue '" + destFilename + "'. Error: " + error);
// Log the error
console.log("Failure: " + error);
I get the following error: Unhandled ReferenceError: fetch is not defined
If I define fetch like that:
let fetch = "";
I get the following error: Unhandled TypeError: Expected a function.
How to get an File from Internet (on Fitbit Simulator) ?
Cheers,
NoWo
Best Answer11-23-2018 09:29
11-23-2018 09:29
You're confusing code which must be run in the companion, not on the device. fetch() is companion only.
11-18-2018 11:37
11-18-2018 11:37
If you're using typescript (as opposed to straight javascript), I think this can happen. There may be an import or something that defines fetch in this situation.
Best Answer11-19-2018 04:02
11-19-2018 04:02
Hi Catplace,
i don´t use typescript, only Fitbit Studio and Fitbit Simulator.
It has to be possible, many Apps/Clocks can get Data from Internet, I think they use fetch, but when I use fetch I get the these errors 😕
11-23-2018 09:29
11-26-2018 14:05
11-26-2018 14:05
Hi JonFitbit, I get it done 🙂
As I think to use the companion-Part there must be an actice connection to Smartphone.
But now I´m wondering because the Ionic has WiFi connection but needs connection to the Smartphone, which itself uses the WiFi to get the data via fetch() to send via messaging to the App (Clock Face).
Is there a Way to use the WiFi of the Ionic for getting data (simple text) without need of Smartphone?
Best Answer11-26-2018 14:51
11-26-2018 14:51
There's no way to fetch without using the companion. Device wifi is only used for firmware updates and music transfer.
