04-13-2024 14:58
04-13-2024 14:58
is there any way i can configure my project to allow versa 2 usage after i created the project, when i created this project, none of the devices were checked and versa 2 was not an option so my stupid brain decided to press enter, so now i cant use any device with it, and i would also like to be able to use a versa 2
Best Answer04-13-2024 15:02
04-13-2024 15:02
04-14-2024 08:31
04-14-2024 08:31
Thanks! I had realized that I forgot to put Mira in the build targets then build it again.
Best Answer04-14-2024 11:51
04-14-2024 11:51
I also had to set the sdk version to 4 manually
