I have noticed that my settings do not work in 5.0, but worked fine in 4.0. I think the problem is that the fs.readFileSync() function is returning undefined and causing problems. I have pasted my app/simple/device-settings code below.
Responsible for loading, applying and saving settings.
Requires companion/simple/companion-settings.js
Callback should be used to update your UI.
import { me } from "appbit";
import { me as device } from "device";
import * as fs from "fs";
import * as messaging from "messaging";
const SETTINGS_TYPE = "cbor";
const SETTINGS_FILE = "settings.cbor";
let settings, onsettingschange;
export function initialize(callback) {
console.log("init");
settings = loadSettings();
onsettingschange = callback;
onsettingschange(settings);
// Received message containing settings data
messaging.peerSocket.addEventListener("message", function(evt) {
console.log(evt.data.value);
console.log(settings);
settings[evt.data.key] = evt.data.value;
// Register for the unload event
me.addEventListener("unload", saveSettings);
// Load settings from filesystem
function loadSettings() {
try {
console.log("file loaded")
return fs.readFileSync(SETTINGS_FILE, SETTINGS_TYPE);
} catch (ex) {
console.log("no file found")
return {};
// Save settings to the filesystem
function saveSettings() {
fs.writeFileSync(SETTINGS_FILE, settings, SETTINGS_TYPE);
Best AnswerHas the 'simple' code and its documentation been updated for SDK 5/6? I'm pretty sure that readFileSync still works.
This is a long shot, but I wonder if the old-style import statements might be problematic.
Best Answer@Gondwana I am not sure if it has been updated, but something in its infrastructure may not be supported in SDK 5/6. I will look into the import statements.
