04-17-2018 07:29
04-17-2018 07:29
I am building my first clockface for my new fitbit versa. I receive readings from the geolocation API, but all fields contain zero as the value. It appears that the device believes it is receiving a reading from my phone, but there it is not valid. Even when I cause my phone to pull its location (Google Maps or even the fitbit app), the zero values remain.
I have attempted acquiring the value both from geolocation.getCurrentPosition() and geolocation.watchPosition(); both supply the same zeroed-out readings.
I have Location enabled in package.json, so it shouldn't be a permission issue (there should be an error event in that case).
Sample reading:
{"accuracy":0,"latitude":0,"longitude":0,"altitude":0,"altitudeAccuracy":null,"heading":0,"speed":0}
04-17-2018 07:53
04-17-2018 07:53
Does the Fitbit mobile app definitely have access to location information in your phone's privacy settings?
Best Answer04-17-2018 21:29
04-17-2018 21:29
I did check that early on and confirmed that all permissions are granted (including Location). I am developing for Android which displays an entry in the tray every time the GPS is queried.
When I call `geolocation.getCurrentPosition()` at a regular interval, I see the GPS entry appear at the same interval as those calls. When I register listeners with `geolocation.watchPosition()`, the GPS entry never leaves.
As soon as I disable the GPS portion of the app, the GPS entry disappears and remains absent. Clearly, the clockface is triggering the GPS activity, but the values remain zeroed out.
Best Answer04-19-2018 13:30
04-19-2018 13:30
Can you put your project, or a minimal sample project onto Github, and I'll take a look on iOS and Android and see what's happening.
Thanks
Best Answer04-20-2018 19:32
04-20-2018 19:32
I have made that version of the clockface available here: https://github.com/joeledwards/iso-plus/tree/location
Let me know if you have any additional questions about the issue.
Best Answer07-13-2018 05:30
07-13-2018 05:30
Did you ever figure this out? I'm having the same issue.
Best Answer07-13-2018 08:23 - edited 07-13-2018 08:28
I did get this working eventually. However, every time I pulled the Geo info, it would wake up the GPS. This resulted in a continuous query for GPS info and it ended up being a drain on my phone battery.
I suspect this is only an issue if you are attempting to incorporate this into a watch face.
Here is the app code for the version of the watch face which was pulling geo info successfully:
https://github.com/joeledwards/iso-plus/blob/location/app/index.js
UPDATE:
I needed to add a permission request into my package.json (also available in the above repo at the location branch).
07-27-2018 03:07
07-27-2018 03:07
Joining late at the party but i had a slioghtly different problem with the Companion watchposition.
It alternates between a good reading and zero reading. My ugly solution was ?
if(!("latitude" in **ahem**.coords)){
if(debug)console.log("latitude not defined");
}else{
position = **ahem**
