Hi!
Do you guys have any idea of how to add an custom png icon into
In the index.gui file I have an image like this:
<image id="stepsIcon" href="Images/heart-walk.png" load="sync" />
What I try do is to get this image into one variable. At the moment as an example I do this with an HTML heart icon as you can see below in the code. The reason for this is that I would like to "group" the icon and the text as one single element, so I can position this a bit easier, instead of having two element, one for the image and one for the text.
Any ideas?
const hrm = new HeartRateSensor();
hrm.onreading = function() {
currentHeartRate.text = ("♥ " + hrm.heartRate || 0);
currentSteps.text = (today.local.steps || 0 );
hrm.stop();
function updateOther() {
hrm.start();
setInterval(updateOther, 1000);
Hi! Yes you can group them inside a svg, like this:
<svg id="gr_23" >
<image id="stepsIcon" href="..." load="sync" />
<text id="stepsLabel" />
</svg>
and then, in your styles.css, position them as desired
#gr_23 {
x: 68%;
y: 91;
width: 33%;
height: 24;
#stepsIcon {
x: 0;
y: 0;
width: 24;
height: 24;
fill: red;
#stepsLabel {
font-size: 24;
font-family: System;
text-length: 8;
text-anchor: end;
x: 100%;
y: 100%;
fill: red;
The fun part? coordinates for the icon and label refer to the parent svg, so it's really easy to layout this ensemble.
