10-11-2017 08:16 - edited 10-11-2017 18:03
How do I rotate a "g" element in javascript?
document.getElementById('g_element').transform = 'rotate(15)'; ?
I mean, how do I rotate the clock hands in javascript?
10-24-2017 20:54
10-24-2017 20:54
Yup. Thanks to another person in the Discord channel I was able to get a nice analog clock going and now working on customisable faces 🙂
10-12-2017 03:17
10-12-2017 03:17
JavaScript rotation is coming in the next update, we'll have some new documentation for you.
10-20-2017 18:50 - edited 10-20-2017 18:51
@JonFitbit any idea when that's coming? From what I can tell, analog faces aren't possible at the moment. I've got a rotation on an SVG but don't seem to have a way to manipulate it based on the current time...
10-21-2017 11:20
10-21-2017 11:20
If you look on the community Discord server, you'll find a pinned example of creating an analogue clock. Search this site for the Discord url.
10-24-2017 20:54
10-24-2017 20:54
01-09-2018 09:54
01-09-2018 09:54
I have searched in discord but can not find anything that helps me.
You don't mind posting an example here?
Thanks in adv.
kmpm
01-09-2018 10:34
01-09-2018 10:34
Thanks in adv.
kmpm
The clockface guide now contains an example https://dev.fitbit.com/build/guides/clockfaces/
You can also take a look at the Rotation Animation section here https://dev.fitbit.com/build/guides/user-interface/animations/#transformation-animations
09-04-2018 20:52
09-04-2018 20:52
How do I rotate an item but not always start at 0 degrees? I want to start at 45 degrees and finish at 135 degrees.
function stepsToAngle(steps){ //return Math.Floor((360 / 10000) * steps); return (((90 / 10000) *steps)); if (steps > 10000){ return (((90 / 10) * steps)); } }
