09-23-2018 07:14
09-23-2018 07:14
hello from a french dev newbie
I just start to develop my own apps.
I try to create a simple app in order to shutdown in One click my versa instead of searching shutdown in parameters menu.
Is there a command for device shutdown?
thanks for your help
merci pour votre aide
Best Answer09-24-2018 10:18
09-24-2018 10:18
Hi, unfortunately that's not possible with the current SDK.
Best Answer09-24-2018 23:31
09-24-2018 23:31
zut alors!
thanks for the answer.
i will propose it in improvments
