09-21-2018 14:11
09-21-2018 14:11
on some of the clock faces there are either 2 lines above or below for the zones. are there icons for this or is it just text ?
09-23-2018 12:30
09-24-2018 08:16
09-24-2018 08:16
Hi Carol i thought it was all clock faces which is why i didnt give more detail. as far as i know there are 2 lines above if in fat burn for example ? and 2 lines below for another zone ? i have seen this on the moment clock face if that helps but i think it is on the standard one as well
09-24-2018 11:20
09-24-2018 11:20
@sleedoh, I’m afraid I still don’t understand your question. Are you referring to the clock faces available on the Versa and Ionic? (Maybe I should have asked that first.) I have a Versa and use the Stats clock face. My HR just shows BPM. - no lines. If you could provide a picture of an example, it would be helpful.
09-24-2018 11:31
09-24-2018 11:31
Does this help? https://help.fitbit.com/articles/en_US/Help_article/1565#zones
09-25-2018 04:08
09-25-2018 04:08
That’s a good article, @JonFitbit. Thanks for providing it! Back to your original question:
“on some of the clock faces there are either 2 lines above or below for the zones. are there icons for this or is it just text ?”
In my experience with clock faces, I’ve only seen text, as shown in my example.
09-26-2018 12:53
09-26-2018 12:53
thanks Jon this is what i am referring to.
So how are the two lines is is just the image with 2 dashes above or below?
i would of thought it would of been an image as the heart shrinks and the lines appear and would be much easier to add but i wanted to be consistent.
