I am getting the following error...
"Error 22 Invalid attribute 'data-size' in animate-in mnt/sysassets/widgets_common.gui:301,1"
It doesn't seem to cause an issue with my clockface, but it annoys the carp out of me. I don't like seeing red in my build results or console output, I will even try to fix warnings if I can.
It can't be related to my "code" as it gives the same error if I create a new project for Sense/Versa3. I do not get this error for Versa2/etc.
If I click on the blue link to ".../widgets_common.gui" I am told the file does not exist. How can there be an error on line 301 of a file that does not exist?
Yes... I am new here. Yes... I searched but only found things relating to sdk5 and older.
Thank you for the reply!
I will try soon, it's been some weeks since I have mucked with it. Strange though that I get the same error with a new, untouched project.
Edit: Eh? Why is my reply marked as the best answer? My big fat thumbs? Yours should be marked as such, sorry.
This is because you are using code for SDK 4.X, but that has some changes to SDK6
Read here for the steps to be done:
https://dev.fitbit.com/build/guides/migration/#sdk-4-x-to-5-0
Godwana stuff seems to refer to SDK 4.0 (not migrated to SDK 5.0(. I am referring to SDK 5.0.2 for Sense instead of 6.1.0. See migration from 4.0 to 5.0
Best AnswerI get Error 22 when using cycleview in SDK6. I now ignore it.
