05-23-2021 22:57
05-23-2021 22:57
In this code below, is there any function to call the filename?
When I use "inbox.nextFile();" I get error msg that "e.inbox.nextFile is not a function"
import { inbox } from "file-transfer";
// Process the inbox queue for files, and read their contents as text
async function processAllFiles() {
let file;
while ((file = await inbox.pop())) {
const payload = await file.text();
console.log(`file contents: ${payload}`);
// Process new files as they are received
inbox.addEventListener("newfile", processAllFiles);
// Also process any files that arrived when the companion wasn’t running
processAllFiles()
Best Answer05-23-2021 23:34
05-23-2021 23:34
Are you possibly trying to run device API code in the companion?
Best Answer05-24-2021 09:47 - edited 05-24-2021 10:00
No, I am not.
I am trying to transfer a file from device to companion which has its local storage and I need to get the name of file.
I know how to store it in local storage but don't know how to get the name.
Best Answer05-25-2021 05:42
05-25-2021 05:42
In your example, it's file.name
https://dev.fitbit.com/build/reference/companion-api/file-transfer/#readonly-name
