06-10-2020 01:24
06-10-2020 01:24
Hi,
I want to build an app that streams heart rate from the watch itself to perform some algorithims. Is that possible?
Best Answer06-10-2020 01:30
06-10-2020 01:30
Not from Charge 4. You can only get that data from the Web API.
Best Answer06-10-2020 02:09
06-10-2020 02:09
Does the Versa support this?
Best Answer06-10-2020 02:19
06-10-2020 02:19
Yes, but getting the data is pretty tricky. You can't just save it directly to a file. You have to send it to a server using fetch() or WebSocket.
But it can be done!
