I am interested in writing a device and companion app for the luxe and charge 5. Is this possible? If not, then I am really interested in accessing the current hr value in the fitbit mobile app from an sdk companion app. Is there an api, or a class I can instantiate that will hand me that data? If I can get that, then I do not need to create a device app.
The device and companion APIs only exist on Fitbit OS watches (Versa* and Sense*). For Luxe and Charge, you'd need to use the Web API. However, that is only updated whenever the watch syncs.
ok so I see the FitbitMobile app receiving the hr bpm from the Luxe every second. I would assume then that the FitbitMobile app is acting as a companion app to the program running on the Luxe that is emitting (transfer_file?) the hr value every second. Is there a way I can install a companion app in the FitbitMobile app that is able to view that emitted hr value? Like listen for a file_transfer event, a websocket event? I would assume that is the type of communication the Luxe does back to the FitbitMobile app to emit hr values.
Best AnswerSorry, no, the Fitbit mobile app doesn't provide any hooks for third-party code, other than hosting companion code for Fitbit OS watches.
