04-22-2019 07:44
04-22-2019 07:44
I haven't made any changes to my clock face any a long time (5 months ago or more). I logged into the studio.fitbt.com today to add calories to my clockface. I tried to build and was told to pick a SDK Version; I picked 3.1 and tried to build again and got the error "tools.js is imported by app/index.js, but could not be resolved". Then I tried SDK 3.0 and got the same thing.
Is there something I need to change since I was forced to select a SDK version.
The code is out on GitHub: https://github.com/grumpy-coders/rpg-time
Best Answer04-22-2019 14:05
04-22-2019 14:05
If you're not already doing so, try specifying imports to local files using relative references; eg,
04-22-2019 10:58
04-22-2019 10:58
Update:
I tried another one of my apps.
All I did was open the IDE (studio.fitbit.com) and press build. Forced to select an SDK version. Same error with a different js file: DeviceInfo.js is imported by app/classes/GameState.js, but could not be resolved.
04-22-2019 14:05
04-23-2019 04:54
04-23-2019 04:54
The "./" was the key.
I had tried "app/tools.js" and "./app/tools.js" but not "./tools.js"
I'm not sure what changed because it used to work; but thanks that fixed it.
