07-29-2021 10:51
07-29-2021 10:51
units.temperature gives the wrong results. user has the right settings set to Celsius, but because distance units is not KM the units.temperature returns "F" - is this a known issue?
07-29-2021 11:49
07-29-2021 11:49
Temp units is set separately in the setting the the Weather app, apart from general units selection.
I don't know how that relates to the development programming.
07-29-2021 11:57
07-29-2021 11:57
Thanks JohnnyRow.
I might not understand the setup, but I thought that the user settings that you define in your FitBit mobile app in the App Settings / Units section is what the units.temperature will return.
