08-27-2021 00:53
08-27-2021 00:53
i have been searching the web api as well as SDK references to obtain clear answers regarding the possibilty to use fitbit inspire 2 fitness treacker to create an app that collects. stores and transfers on device sensor data specifically acceleromoter and heart rate data to be used by 3rd party android app as part of research experiment conducted on multiple people
Can you kindly confirm to me the possibility of achieving this objective for research purposes ?
thank you
Best Answer08-27-2021 01:22
08-27-2021 01:22
You'll be able to get heart rate from the Web API, but not accelerometer. Inspire isn't compatible with the other APIs.
08-28-2021 23:59
08-28-2021 23:59
thank you for the information
so which model of fitbit trackers will be helpfull for my experiment
as i mentioned
i want to collect both accelerometer as well as heart rate data for my experiment
thank you for the help
Anood shakeel
Best Answer08-29-2021 00:07
08-29-2021 00:07
Ionic, any Versa, or Sense.
Be warned that this is very difficult to do. Browse this forum carefully before spending any money, so you know what you're getting yourself into.
Best Answer08-29-2021 00:24
08-29-2021 00:24
oh i see
thank yoi for the advice
Regards
Best Answer09-13-2021 05:52
09-13-2021 05:52
hello
i was reading through the posts in the community
as its mentioned that heart rate data is stored at 5 seconds time interval
is it possible to obtain the heart rate data at 5 seconds interval from the heart rate api ?
