I'm trying to build my app to my fitbit versa and it builds correctly to the emulator but when I try build it to my versa 3 it disconnects and then the build fails, you can see the full error message here and the other one here, I've had a look at various other topics like this one but nothing on there works. My final app size is 14MB but all my assets and code amount to around 8MB so I don't believe its a size error
Hi @Itsbailey - that seems quite a large file, so a couple of things you can try.
