11-28-2024
20:42
05:13
DavidFitbit
11-28-2024
20:42
05:13
DavidFitbit
kindly inform me where i get the replacement battery of Fitbit Sense watch
Moderator edit: formatting
Best Answer11-28-2024 21:35
11-28-2024 21:35
Hi @ajayan007 there are no replacement batteries from Google. Third party sellers might have one and a service to install it, but you'd never have the factory seal to keep moisture out
Best Answer11-28-2024 22:57
11-28-2024 22:57
11-29-2024 06:04
11-29-2024 06:04
Sorry, @ajayan007 . You'll need to do a search yourself to see what options are available. Fitbit doesn't recommend replacing the battery and I don't know enough about third party services to suggest one.
Best Answer11-29-2024 20:04
11-29-2024 20:04
Hi @ajayan007 - it is improbable that a battery change will work.
If the watch got wet or some other fault caused a short circuit it will cause the battery to fail.
Bulging battery is usually the result of it supplying too much current causing overheating.
Another battery will probably fail in the same way.
Do not attempt to charge or use the watch, it is in a dangerous state.
