Can't get to the GPS setting in my exercises - Sense 2
ANSWERED
I keep reading the instructions for using GPS with exercises on the Sense 2 but I literally can't find that setting anywhere. I go to exercises a select walk and then scroll up and I see a settings thing briefly pop up but then it goes immediately into starting the exercise. I assume the GPS option is in this screen somewhere but I can't access it.
I did a factory reset and same behavior persists. Any help? Thanks
1 BEST ANSWER
Accepted Solutions
Welcome to the Fitbit community, @streadgold!
From what you've mentioned concerning your issue with GPS setting, you seem to have missed to tap an All on the Exercise screen to select a walking exercise and then be able to switch GPS on for that. If you've done that once, from now on you can select this exercise from the Exercise shortcut screen and GPS will work.
To get more details about that, please have a closer look here:
How do I use GPS on my Fitbit device?
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
3 REPLIES 3
Stefan
Perfect! Thanks so much that did the trick.
You're welcome, thanks for your feedback, @streadgold!
Glad I could help you. If you have any further questions, do not hesitate to come back!
Stefan
