I have a co-branded credit card that has the iPass function, while I was able to add the credit card to my Google wallet, I can’t add the iPass card associated with it. I’ve added the same card to my Versa 3 previously without any problems, I’ve also tried removing the credit card on Sense 2 and reinstalled it as per the instructions in the “Help” section. Anyone out there with the same issue?
Best AnswerHello @PL7706 and welcome to the Community. I found this Fitbit iPass Help article when I searched. Is this the same one you used? Is your location set to Taiwan? I'm not sure you will get help from a fellow iPass user here, since iPass is a Taiwanese contactless payment system.
Laurie | Maryland
Best AnswerThanks for the reply. Yes, it’s what I’m using, and yes I’ve browsed through all the relevant posts I can find in “Help” and “Forum” and set my location to Taiwan and tried reinstalling the card…basically tried everything but nothing worked
