11-15-2023 15:11
11-15-2023 15:11
Since changing to Google I no longer get my daily % for Time Asleep, Deep & REM, &, Restoration
11-17-2023 13:59
11-17-2023 13:59
Welcome to the community forums @Robinbjoy
I'm sorry to know the difficulty that you are experiencing with sleep.
Keep in mind that you must see sleep stages in order to see a correct sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Sense 2 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.
In case the problem is related to the Fitbit app, please try the following as well:
