Customize Exercise Label
For over 30 years, I' a custom exercise program called NIA, as do hundreds of thousand nationally and internationally. With Sense 1 I could add custom exercise to Dashboard, so I didn't have to group it into its closest category of Aerobics, which NIA is not.
That function no longer exists. I'm stuck with generalized data, and not a true reading of stats.  If there is a way to add a custom exercise, and I have this wrong, please let me know.  Otherwise, please add that back in firmware update if possible, and not another to-be-paid-for add on...
Many Thanks ~
1 REPLY 1
Hi, @TeriPDX , unfortunately, as you have noted this facility was removed once the web based Fitbit Dashboard was discontinued.  The best way of making your views known to the development team is to post in the Product Feedback board.  A few weeks ago I created exactly this request and you can find it here I would recommend voting for the return of this feature and also adding your voice in the comments below.  The more voice and attention the feedback gets the more likely it is to be implemented.
