03-17-2026
11:21
08:57
AndreaFitbit
03-17-2026
11:21
08:57
AndreaFitbit
About a week ago my Fitbit stopped worked. It says it has plenty of battery but won't turn on. Thoughts?
Moderator Edit: Clarified subject.
Best Answer03-17-2026 11:27
03-17-2026 11:27
Hi @BeachBabe62 and welcome to the forums.
Thank you for your message. I'm sorry to hear about your device not turning on.
Can you see the lights on the back of the pebble?
Please try for now the steps explained here: How to fix a blank, unresponsive, rebooting, or flickering Fitbit device screen
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Best Answer03-17-2026 11:42
03-31-2026 08:15
03-31-2026 08:15
I have a Fitbit Sense 2. Sorry - had massive work commitments and just ended up taking off and wearing a regular watch.
Best Answer03-31-2026 08:26
03-31-2026 08:26
So I've had a grueling few weeks and finally just took it off and used a regular watch. When I press and hold i get the icon - the first time I did this the icon came on and off, ended with a big red X on the screen, and went blank again. Ive hooked to the charger but unlike other times, it doesnt go on but there is some vibrating. Is it dead? How do I contact technical support? I'm thinking it is more than 2 years old.
03-31-2026 13:45
03-31-2026 13:45
Hello @BeachBabe62
I moved your thread from the Android app forum to the Sense 2 product forum since your issue is with your device, not the app.
Here's the link to contact Fitbit Support (<-- click). Complete the prompt in Step 1. Tap Continue in Step 2 (ignore Resources) to get to Step 3, which has the contact options for Support.
