10-09-2022 03:02
10-09-2022 03:02
I think cEDA is just stealing all the CPU cycles. Once I turned off cEDA the GPS did much better, almost as good as the original Sense. And battery use got a whole lot better too.
Best Answer10-09-2022 06:29
10-09-2022 06:29
Just an impression. I tested with and without cEDA and it works the same. For me, GPS works quite well in general (compared with other GPS devices).
Best Answer10-09-2022 06:33
10-09-2022 06:33
I think my GPS is shaky because I live in the mountains and have a lot of trees nearby. Made a big difference for me!
Best Answer10-09-2022 17:42
10-09-2022 17:42
Where to turn the CÉDA off? Thanks
Best Answer10-09-2022 23:43
10-09-2022 23:43
@Michelle88 if you don't know then it is off (it is off by default). You turn in on/off in the mobile app in the settings under Activity&Wellness and then Stress Management.
