07-19-2025
20:25
21:05
ManuFitbit
07-19-2025
20:25
21:05
ManuFitbit
Which clock face can I download to include total steps, hourly steps and heart rate? I just had to replace a Sense 2 and it had a pumpkin face with all those stats. Help? This is frustrating
Moderator edit: clarified subject.
A warm welcome to the forums @jjeerens.
Thank you for sharing the inquiry regarding your Sense 2.
Could you please try to check a clock face designed by Fitbit? Most of them include comprehensive statistics.
Please take a look at the following link: https://gallery.fitbit.com/
Best Answer@jjeerens I'm very sure you are looking for this: -Time 4 Fall- I found it by putting using 'hourly steps' as my search term in the search field. That developer is named Amy. If you put Amy in the search field, you will find all of her clock faces. Several others show hourly steps, so you don't have to look at pumpkins all year, unless you want to. So thank you for your issue! I just downloaded -Floral-.
@ManuFitbit Fitbit doesn't make any clock faces that show hourly steps as a stat.
Laurie | Maryland
