02-22-2023
18:12
16:22
LizzyFitbit
02-22-2023
18:12
16:22
LizzyFitbit
I have spent three hours trying to get assistance. No one has been able to tell me which glue to use in order to attach the glass to the chassis!
Best Answer02-22-2023 19:15
02-22-2023 19:15
Hi @cmp1721 since you're dealing with customer support, they aren't going to know the precise glue that is used in the manufacturing process. Even if you did know which glue, your Fitbit would never be the same as when it came from the factory. Are you under warranty?
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
