12-03-2024
02:08
10:44
LizzyFitbit
12-03-2024
02:08
10:44
LizzyFitbit
Has anyone found a photo clock face for Sense 2? Can't find one in gallery and other apps say unsupported by fitbit and proceed with caution so worried about using those. Thanks
12-10-2024 11:00
12-10-2024 11:00
Welcome to the forums, @Dragon100. @Guy_ Thanks for your insights.
@Dragon100 Thanks for checking our App Gallery and I'd like to share with you that the Photograph clock face created by Fitbit isn't available for Sense 2. However, there are other 3rd-party clock faces that will work well with your watch.
In regards to the message, some clock faces developed by a 3rd-party will prompt you with that warning in case a payment is required to use it. But, aside from that, it should work correctly and for any feedback you can always get in touch with the developer.
Best Answer12-03-2024 20:41
12-03-2024 20:41
Hi @Dragon100 - in the Fitbit App, Gallery tile, try searching clocks for "Photo Background Clock".
This is a clock (as example) for the Sense 2 which has a photo but if you live in the EEA you won't see it, only Fitbit clocks are available. In that case search for just "photo", just in case there is one.
12-10-2024 11:00
12-10-2024 11:00
