How do I get vibrations for Sense 2 body responses?
How do I get a vibration notification on my Sense2 when I've had a stress response? I often (usually!) notice the " how are you feeling?" window long after a stress response has occurred. It's utterly useless in terms of trying to assign a feeling state so long after the fact. Is there a way to make my Sense2 vibrate at those times, so I can get a clear connection between feeling state and stress response?
3 REPLIES 3
Welcome to the community forums, @StayingAlive70.
Thanks for letting me know about your Sense 2 and let's work on this together! Before anything else, let me explain that you should feel a vibration along with the message displayed on your watch if a body response was detected some time ago. If this doesn't happen, I'd suggest the following steps:
  1. Force quit the Fitbit app and reboot your phone
  2. Restart your watch to refresh its performance
  3. Open the Fitbit app and tap on the Body Responses tile
  4. Tap on the gear icon at the upper right corner
  5. Turn the Body Responses and Notifications off and back on
  6. Wait and check if the notifications are sent correctly this time.
That being said, please note that the body responses will appear minutes after detecting a change in your stress level. I understand how helpful it'd be to get those notifications right after sensing a change and my best advice is to share this idea in the Product Feedback board. This will allow our developers to work and make improvements on our products.
Thanks this info helped. I realized I was in Sleep Mode and once I changed that, I began getting vibration notifications. I still would like to be notified closer to a stress response, but now I'm receiving those notifications much sooner than before.
@StayingAlive70 It's good to see you here.
Thank you for your kind words and for sharing the steps that worked for you. I understand your point about getting sooner body responses and I encourage you to post your idea in the Product Feedback board to get the attention of our developers.
Wishing you a great weekend ahead!
