Hi @bparker, thanks for stopping by, I hope you're doing well.
Let me help you with your question about which stats you are able to see on your watch.
At this moment, the option to see your weight on the Smartwatch is only available with the Sense and Versa 3. I appreciate your understanding.
This feature is known as "widgets". You can learn more about the available widgets in our help article How do I navigate my Fitbit device?
Happy 2025!
Hello @bparker Thanks for stopping by, I hope you're doing well.
I appreciate your feedback regarding this feature.
We are constantly working to improve Google and Fitbit products and services, and we usually remove some features to update or integrate some others. I appreciate your understanding.
You are always free to share your opinion. The best place to make your voice heard about this is the product feedback board.
I just searched and it seems there are several suggestions about the widgets feature but none exactly like the one you suggest. So you can create one, add your comments so that other members can vote for this suggestion
Thanks for your feedback and for participating in the community!
