01-17-2023
00:43
11:32
LizzyFitbit
01-17-2023
00:43
11:32
LizzyFitbit
Sense 2, is sleep mode not automatic like Charge 4?
Best Answer01-17-2023 14:26
01-17-2023 00:52
01-17-2023 00:52
It is definitely automatic, why do you have the impression that it isn't? Any malfunctioning?
01-17-2023 11:53
01-17-2023 11:53
Just bought the sense 2. On the charge 4 you had to specify the sleep.mode start and finish times in the settings. Cannot find anything similar on the Sense 2 settings apart from manually being able to put it into sleep mode.
01-17-2023
23:03
15:52
01-17-2023
23:03
15:52
Hi @malgpz900 - just to be sure, Sleep mode to measure your sleep is automatic as @Dopovo says.
However there is an option to turn on Sleep mode in Quick Settings and better still to schedule it in watch Settings, Quiet modes.
This option merely puts the watch to sleep and has no bearing on your sleep. It stops any notifications waking you or the watch display coming on inadvertently, and if you wake it intentionally it should be Dim.
01-18-2023 13:02
01-18-2023 13:02
Yeah thanks. I know the function,.just could work out how to set it. Sorted now.
