02-27-2025
08:28
11:10
LizzyFitbit
02-27-2025
08:28
11:10
LizzyFitbit
02-28-2025 05:08
02-28-2025 05:08
Hi @dmcliv and @apayne1990. I don't know if this will help you or not. Please try the following path:
There is a note at the bottom of the page that says all permissions need to be on to function properly. To be honest, I don't use the Weather app on my Sense 2. It doesn't give me current information -- always old information.
Laurie | Maryland
02-27-2025 11:51
02-27-2025 11:51
I am having issues with my sense 2. I have had it for 3 days and it is driving me insane. If my sense didn't have a cracked screen I would switch back.
I have an android phone and keep weather the weather alerts too. I had mirror my phone set up so I have turned that off in hopes I don't get that notification. I am having issues where i get the vibration of the new notification but it take 10 -15 seconds before the actual notification shows on my watch.
Best Answer02-28-2025 05:08
02-28-2025 05:08
Laurie | Maryland
02-28-2025 06:16
02-28-2025 06:16
Any idea how to help with the lagging of my notifications on my sense 2? I have tried the troubleshooting and it hasn't helped. My sense 2 will vibrate with the notification, but then it takes a good 10 - 15 seconds before it shows the actual notification on the screen.
Best Answer02-28-2025 06:36 - edited 02-28-2025 06:38
I think mine takes a while as well.
Best Answer02-28-2025 06:39 - edited 02-28-2025 06:40
LZeeW This worked!!! Thank you so much.
02-28-2025 07:37
02-28-2025 07:37
@apayne1990 @dmcliv I'm sorry, but I don't have any specific troubleshooting advice. My notifications show up immediately on my Sense 2.
Laurie | Maryland
