How do I turn on Smart alarm on Sense 2?
How do I turn on the smart alarm?
1 REPLY 1
Just push the side button to get to the list of apps, choose alarm, and set it there when creating a new alarm. First you need to set a time and it will be saved. And after that you go back to the list of alarms you have created. By clicking on the set time you will be able to edit, and you see the 'smart wake' option. To get the full information on setting up the alarm option you can use the online manual: Timekeeping
HHope this helps.
Tracking my health and movements with Fitbit from april 2014, now using a Sense 2™
