How do you save the middle display setting for an exercise?
Hello,
Someone else had the same problem. I want to save the middle stat on my Sense 2 to always be elapsed time, but every time I start a run, I have to toggle through and select it. I want it to be the default so I don't have to select it every time.
2 REPLIES 2
Hi @ccasciolaIt’s good to see you around in the forums!
Thanks for bringing this to my attention. I understand your concern, I will do my best to help you with this.
To customize the stats you want to be displayed in the middle of your exercises, please do the following:
  • On your watch, open the Exercise app.
  • Swipe through the list of workouts to find the one you want to customize.
  • To customize the statsSwipe up to have the exercise settings. In the Show stats section, tap Top, Middle, or Bottom to choose the stats you want to access.
  • Return to the exercise screen: Swipe down until you return to the exercise screen with the Play icon
  • Select Play to start the workout.
MariLu | Community Moderator, Fitbit
Believe and act as if it were impossible to fail.
I want to save the middle stat so that I don't have to toggle through it each time. How do I do this?
