The SpO2 has been reading 95 since I got the watch, which is the same as a finger O2 tester. Today it's reading 92% - the finger tester is 95/96.
If it was 92 I'd be worried 🙂
I've restarted the watch, and wiped the back, no change. Is this reading generally inaccurate or do I have a problem?
Best AnswerThe SpO2 readings you get from Fitbit are overnight readings while you are asleep, not the same as an on-demand finger tester while awake. From the Fitbit Help section
From that, it sounds like 92 overnight is nothing to be concerned about.
