Is there any Fitbit device similar to Sense 2 but smaller?
Hello,
my wife likes my Sense 2 but would like a smaller Fitbit that has similar features. Is there one that you recommend?
Thank you
Angelo
5 REPLIES 5
Hi @Angelo777  - you'll have to look at other brands for smaller smart watches, even consider children's ones.
Welcome, @Angelo777.!
If your wife's main focus is on Fitbit's health and fitness functionality in a small form factor, I'd suggest having a closer look at Charge 6.
As I've seen that you had used Charge 5 yourself before switching to the Sense 2, I'd like to point out that Charge 6 has improved sensors and is able to use Google Maps turn by turn navigation now as well as Google Wallet.
Fitbit Charge 6
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2, Pixel 4a, Pixel 7
Thank you for your reply. She would prefer a model that can also answer
calls. Which other models do that other than the Sense 2?
@Angelo777   If you are asking about On-Wrist calls, where you can answer and speak into the device, that is only available on the Sense/Sense 2/Versa 3/Versa 4.  Other models can answer calls, but you are answering the phone.
Laurie | Maryland
Understood. Thank you.
