09-23-2022 03:48
09-23-2022 03:48
My wrist is just over 5 inches in circumference (14cm) and I have yet another broken charge 4 so am looking to upgrade. I would really love a Sense 2 but am worried it will be too big. Anyone with small wrists able to say whether it works for them or not please?
Best Answer09-23-2022 06:09
09-23-2022 06:09
@Clothmadmummy my wrist is 15 cm and I wear the original Sense, which has similar dimensions to the new Sense 2. I find that it actually fits better than the Charge 4 because the pebble is not as long. Of course, the Sense does look large on my wrist but to me the added features are worth it.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
09-23-2022 06:14
09-23-2022 06:14
Thanks for replying, that's really helpful.
09-24-2022 01:09
09-24-2022 01:09
Hi @Clothmadmummy - The specs for the Sense and the Versa 2 are the same
Both small and large sizes included in box.
Small: Fits wrist 5.5" - 7.1" in circumference
Large: Fits wrist 7.1" - 8.7" in circumference
However, do consider carefully what things you need, as you may find the Versa 2 a much better watch, for charging, vibrations, heart rate, floor count and reliability, no to mention the established menu system which is more complete and simpler.
Best Answer09-24-2022 04:24
09-24-2022 04:24
I have very scrawny wrists and using the small band I still have 2 holes left unused. While it dominates my wrist visually it doesn't feel uncomfortable at all. Wish I could add a photo ☹️
