The calories on my Fitbit are syncing with the app- the main tile on the home page has the same number. However, when you click the calories tile to see the breakdown, the overall number is then different (doesn't match the watch and is around 300 calories different). I've tried un-installing, clearing cache, Bluetooth on and off etc. But it hasn't been resolved. Thanks!
Best AnswerI decided to compare the calories burned between my Sense 2 and the Fitbit app. I also notched a major difference between the two, The Fitbit app was much higher. I did some digging, in my case, it looked like the Fitbit app was also pulling calories burned from Google Fit and adding it to what the Sense 2 was reporting. I disabled the ability to write to Calories burned through Google Fit through Android's Health connect. I will see if everything matches up.
I am not sure if you use Android or Apple, but if you use Android, that is something you might want to look at.
