05-01-2025 08:21
05-01-2025 08:21
After the latest firmware update, my Sense 2 has no battery life. On a full charge it now lasts about 7 hours and will shutdown even when the battery percentage says 38. It also takes about 8 hours to charge instead of about 2. It gets worse if I try and track a workout or run.
Best Answer05-06-2025 15:48
05-06-2025 15:48
What was your (# of days) battery life prior to the firmware update? This (potential affect on battery life) is precisely why I have not yet updated my firmware. I heard there was a battery issue with the old Sense (1)m so I was concerned to get feedback from others before updating my Sense 2, even though Fitbit “said” the Sense 2 didn’t have the same issue as the original Sense. I currently get about 5 to 6 days and use my Sense 2 for a lot of th8ngs, so don’t want to ruin it.
Best Answer05-06-2025 17:07
05-06-2025 17:07
Best Answer05-06-2025 20:55
05-06-2025 20:55
@B_Michael , thanks for the info and suggestion. I was very close to trying the update since I've been having an issue with my watch faces not updating my location...I thought maybe the fitbit firmware needed update to link to my new android os 15. But given your experience and other posts about the firmware (aside from issues) adding very little new functionality, I think im gonna pass on the update.
Best Answer05-13-2025 13:48
05-13-2025 13:48
Do you know is there a way to revert back to the old firm wear? I am having similar problems with my. Before the update it would last 5 or 6 days. Now its closer to 3-4. There are also many functions with the fitbit app that dont work correctly. I have been a fitbit user for about 8 years and am getting really tired of things not working like they should.
Best Answer05-13-2025 16:23
05-13-2025 16:23
