Hello. Sense 2 is recording one walk but I don't know how to record multiple please. Is it possible to lengthen showing time of the clockface - I have come from a Surge which showed time continuously. thanks for all help 🙂
Best AnswerHello @Loulou41 and welcome to the Community. Your Sense 2 has SmartTrack, just like your Surge. The Exercise app on the Sense 2 is similar to the Exercise Menu on the Surge, except that it has many more shortcuts. If you are asking about SmartTrack, my Sense 2 records multiple activities in a day. You will also have a record for every activity tracked using the Exercise app. The Fitbit app shows the last exercise on the Today page. Tap on the Exercise tile on your Fitbit app to see all the records for the day.
You can lengthen the screen time by doing the following: swipe down on the screen to go to your Quick Settings. then tap on the Settings (gear) in the upper right. Tap on Display. Swipe up until you get to Screen timeout and adjust it there. Your Sense 2 also has an Always On Display option. It will show a low power version of the clock face at all times, but this uses more battery. You can set the AOD there in the Display settings or you can control it when you swipe down on the screen in the Quick Settings (bottom right icon).
I want to point out a significant difference between your Surge and Sense 2. Your Surge awards active minutes. Your Sense 2 awards active zone minutes. They use different equations and it takes more effort to earn active zone minutes.
Laurie | Maryland
