05-02-2024 08:02
05-02-2024 08:02
My battery started leaking in my sleep and had burnt deep painful holes in my skin where the sensors are located. Fitbit hasn't been helpful, I keep being told it's being escalated but no one has responded in 4 days. Anyone have advice on how to proceed?
05-02-2024 21:38
05-02-2024 21:38
Hi @hunnykat - if the watch overheats it can burn you. This can happen if there is a short circuit inside, sometimes caused by getting water inside.
If it gets hot when charging stop immediately as it confirms a watch fault.
Definitely don't wear the watch on either wrist.
Due to Google lay offs support may be quite limited for dealing with cases such as yours.
