11-21-2023
19:29
08:45
EstuardoFitbit
11-21-2023
19:29
08:45
EstuardoFitbit
I gone through all the settings to use my sense 2 to answer calls. But it doesn't work; calls don't go to sense 2. In Connected Devices on my phone, I'm connected to Sense 2, but there is another device call Sense 2 Calls. I cannot connect to that. Could that be the problem? I have a Pixel 7. TIA
11-21-2023 20:27
11-22-2023 11:47
11-22-2023 11:47
How do I "turn on Sense 2 calls"? I've already completed the fitbit app steps. Thanks.
Best Answer11-22-2023 11:59
11-22-2023 12:04
11-22-2023 12:04
Yes, but my phone cannot connect to "Sense 2 Calls". That's my problem.
Best Answer11-22-2023 12:21
11-22-2023 12:21
@shark37 - if you followed the setup of onwrist calls, you may need to delete any Bluetooth entries for the watch and turn off any other devices running the Fitbit App, then logout and restart the phone and watch.
If you don't get new Bluetooth entries made on login run the set up a device and replace, sync and try again. See also
How do I take on-wrist phone calls with my Fitbit smartwatch?
Best Answer11-22-2023 15:23
11-22-2023 15:23
Try going to Sense 2 page, then clicking “on-wrist calls”, make sure all 3 are checked. If so, click done, the click “notifications” and make sure calls is marked on. After that see if it works…
Best Answer11-22-2023 18:57
11-22-2023 18:57
Nope, didn't work. But thanks for the suggestion
