05-09-2023
08:29
09:46
05-09-2023
08:29
09:46
I have a new sense 2 trying to buy a new wrist strap , I have bought a couple but they don’t fit buying for a sense 2 which I’m told is the same as a versa 3 but this doesn’t seem to be the case??
anyone else having problems?
even the strap fittings look different?
05-09-2023 12:43
05-09-2023 12:43
Hello @Alf63 and welcome to the Community. I own a Sense 2 and a Versa 3. Fitbit bands for these models are marked 24 mm band in the Fitbit Store. Fitbit 24 mm Infinity Band If you older Versa bands have a spring loaded pin, then those are Versa/Versa Lite/Versa 2 bands.
Laurie | Maryland
Best Answer05-09-2023 12:46
05-09-2023 12:46
Best Answer05-09-2023 13:40
05-09-2023 13:40
@Alf63 My example is just one of several 24 mm bands in the Fitbit store. There are others. Some third party bands that say they will fit a Sense 2, but they don't. @Heather-S can confirm, from experience.
Laurie | Maryland
06-17-2023 07:43 - edited 06-17-2023 07:43
there is a small tiny indent difference on the Sense 2 / Versa 4 band mechanism https://strap.primria.com/fitbit-sense-2-versa-4-watch-bands-compatibility/
Best Answer06-17-2023 17:06
06-17-2023 17:06
You were slightly misinformed. My understanding is that the Versa line bands are not interchangeable with the Sense line of bands. You should have gotten a Sense band, which is interchangeable with a Sense 2. Is there any chance you can return the bands?
one cruise ship at a time!
