04-19-2025 10:17
04-19-2025 10:17
After latest update, App doesn’t sync activity that I selected on my Sense 2. Also, trying to add activity manually (after the fact) appears to work, but disappears from App when any other selection is made. Can you help? Thanks
05-08-2025 09:20
05-08-2025 09:20
Hi there @Keith074413!
A warm welcome to the Fitbit Community!
Thank you so much for letting us know that the Fitbit app is not syncing the recorded data from your Sense 2 and for all your efforts.
I suggest you try to do the following:
05-09-2025 06:17
05-09-2025 06:17
Thank you Fatima, I will Try that.
Perhaps you could comment on why some exercise activities do sync but others don’t. For example, if I select “weightlifting” and perform my usual gym routine, the Sense 2 shows the data during the activity, but does not sync and the App does not collect the data. However, if I select “weights”, everything would be fine. Is this a known phenomenon, or (perhaps) the subtle differences in what the activity expects in movement, HR etc that prevents a sensible track. Clearly, I will continue to use the Sense 2 activity that works and most closely matches my routine. Anyway, just wondering if what I observe is my Sense 2….or me😊
