11-16-2022 13:34
11-16-2022 13:34
Just did a factory reset to clear my personal data on my 1-week-old Sense2 and now will not sync to the phone anymore.
I had a different watch face installed ( non-stock watch face) when did the reset. Now on the watch it says, "clock error" and "Go to Fitbit app and try another clock".
Tried shutting Sense 2 off and restarting Sense 2; keeps coming back to same message.
When swipe down on watch face, the "Gear" menu is not highlighted and will not let me select; other items I can select. Also, I cannot get any actions by swiping from right or left.
What now???
Best Answer11-16-2022 13:44
11-16-2022 13:44
Found below from old post and seems to have solved issue as brought Sense 2 back to original factory setup screen asking for language input!!!!
Procedure from old post:
After a few different emails to support - I finally got a response that fixed my Sense being stuck in a reboot loop. Hope it helps.
Please follow the next steps in order to do a factory reset using the buttons:
11-16-2022 13:44
Best Answer11-16-2022 13:58
11-16-2022 13:58
Next issue --- How do you to actually Tune Off the Sense 2 as want to put back into the box.
Pressing the side button and holding for 10 seconds just keeps restarting it?
Any suggestions?
Best Answer11-16-2022 15:01
11-16-2022 15:01
Go to Settings and scroll to the bottom. You will see Shutdown button.
Best Answer11-16-2022 18:13
11-16-2022 18:13
That only works once unit is set and connected to phone.
Anyhow, it's now an "Open Box" returned item at Best Buy.
Best Answer11-18-2022 16:58
11-18-2022 16:58
Then maybe the Sense 2 needs to be setup and an Erase Function needs to be done.
Really the main thing to erase/disable is Fitbit Pay, which can be down through the bank.
From page 64 of the user manual.
