09-08-2025 08:43
09-08-2025 08:43
I have not been using my Fitbit Sense 2 smart watch for a year, since I lost it in my room, and recovered it two days ago. I charged the watch, and it appeared on Bluetooth connection of my smart phone, asking me if I want to connect. When I selected yes , it asked me to enter four-digit code that is displayed on my Sense 2 watch. I pressed the side button for about 10 seconds or so, green Icon appeared and blinked, then went off, then came again and repeated for seven times. At the end of seven times of green icon appearing, blinking and then extinguishing, a red X sign appeared for about a second and screen again extinguished. So, screen did not turn on and watch did not start displaying , so I could not read the code from the screen to enter in the mobile phone to establish the connection. But when I opened Fitbit app. on the phone, it said that connection is on and the phone is synced with the watch. How to recover display on the watch that is not showing?
Best Answer09-09-2025 15:31
09-09-2025 15:31
@asalihbe , A warm welcome to the Community! Thank you for your message and efforts.
In the Fitbit App, from the Today tab, tap the Devices > Sense 2> Sync now. A banner with an update should appear in the app.
If the steps above do not solve the x then try the following:
09-10-2025 01:10 - edited 09-10-2025 01:49
Hi,
The first part of attempt, trying to get update banner or Gallery did not work. Trying with device button, did not work either, since after first flash, I have released the button and immediately pressed again and when I repeated it on second logo flash, it appeared two red cross line across the screen and nothing happened after, no factory reset and display stayed blind as before. Are there any alternative way to execute the factory reset, or display is demmaged, although bluetooth syncing and communication between watch and fitbit application is working correctly. Is it possible that display is demaged, although the green logo and red cross lines are displayed on the screen? Thank you for your support!
09-10-2025 04:32
09-10-2025 04:32
I have a very similar problem, although it seems to have happened after I left the watch uncharged for a few hours. After charging, it displays a screen asking me to choose a language and then tells me to download the App etc. Of course I already have the App (on Android).
I tried your recipe, and I can see a progress bar that suggests it's doing a factory reset, but when it's complete I'm back at choosing a language. I tried that a few times with the same result.
The App thinks it's connected but not synced and telling it to sync doesn't work. The only option in the App is to replace the device, so I tried that and it failed because the Sense 2 didn't display a 4 digit code. The advice from the App then included unpairing the Sense 2 and switching off and on Bluetooth - having done that I got the 4 digit code and typed that into the App.
The App now says Connecting, Sense 2 shows a big tick and says Connected. Both my phone and watch are charging, and they're next to each other.
The App and the Sense 2 are still in that state after about 1 hour 30 minutes - is that normal?
09-10-2025 07:22
09-10-2025 07:22
Update: That continued for more than 3 hours. I then repeated steps 1 to 4 of your recipe, and it's been stuck in the same state for another hour.
09-10-2025 09:53
09-10-2025 09:53
@GrandpaG @asalihbe , Thank you for your replies and further efforts.
As the recommended steps did not work, you already tried everything that we can recommend here in the Community!
Please contact Support. They have more tools that can help check your cases.
Fill up the form.
You'll see some articles recommended and then you'll be able to select how to contact Support.
Provide our team with this URL so that see what you already tried and do not ask you again to perform anything if not needed.
Best Answer09-11-2025 00:26
09-11-2025 00:26
Thank you for your addressing me to official Google Fitbit support site. I already contacted them, and their level of expertise and usefulnes is disappointing! Could you at laast, from your experience, tell me, Is it possible that display is demaged, although the green logo and red cross lines are displayed on the screen? If appearance of the green logo is indication that communication between CPU and display memory is OK, then must be some way of forsing CPU to execute full factory reset and restore proper operation.
Best Answer09-11-2025 09:37
09-11-2025 09:37
@asalihbe Thank you for your reply and feedback.
Please be assured that the feedback will help us improve our services and products.
The display shouldn't be damaged, as it shows the x and the logo. Normally this messages are shown, when an app or clock face is not synced correctly. That's why I recommended the steps in my first post.
As these didn't help, then there is something else that might be causing the issue.
I suggest you continue working with Support and see what they can do for you, and if needed check your warranty.
